Dragon wagon weight limit for rolling around
I have the 3x2 dragon wagon with caster wheels. I know the instructions say it can hold 1500 pounds. But is that 1500 pounds static or is that 1500 pounds that can be rolled around?
I have a engine I’m about to work on that weighs about 700 pounds and would need to roll it around the garage and I’m not sure if the table would be up to it.
Yes no problem. It’s the casters that limit the weight capacity. It will roll just fine with 700 lbs
Cool!
No issues with the legs buckling? Should I throw some support on them half way down
No that’s not necessary. The legs are built to take side loads.
Awesome.. I’ll be sure to take a pic when it gets here
The quality of the floor is often the limiting factor for what you can roll around.
