Plasma gouging or bevel prior to welding
I just acquired a capable plasma cutter. With it I can pretty easily bevel cut or gouge a groove. I have never been happy needing to grind a bevel into edgework prior to welding so my question is whether I can gouge into the two pieces held in their final configuration, and then weld over that trough. Gouging does little heat treatment hardening of the materials, but a bevel cut will definitely have a zone of heat hardening. Is that a problem for subsequent welding (primarily MIG). Material: soft steel typically. Thickness: ½" most of the time. New to plasma cutters, but it sure is fun !
Plasma cutting the bevel is fine, it’s the dross that’s going to potentially contaminate the weld if it’s not removed.
You probably already know this, but in case you didn’t… when plasma cutting, the edge will get some mill scale on it and should be removed for welding
