Which Grinding Disc Should You Buy? A Buyer's Guide Backed by Our Test Data
We put a full rack of flap and fiber discs through the same test, on the same rig, on the same steel, and let the numbers sort them out (and made an entire video series on it). If you have ever stared at a wall of discs trying to figure out which one is actually worth buying, this guide is for you.
If you do not want to read the whole thing, find yourself in the categories below, grab the pick, and get back to work. Every recommendation here comes from our own testing.
A note on pricing: all prices in this guide were collected in 2025 and reflect what these discs cost at that time. Prices change, so check current pricing before you buy.
How We Tested
Two identical grinders, both set at 2.5 degrees, running on mild steel coupons. One coupon was room temperature and the other had its first inch preheated to 1,500°F to mimic grinding right off a weld. We ran the discs at 11,000 RPM, plus a separate light-pressure series at 6,000 RPM, using a 4 lb weight for light pressure and an 8 lb weight for heavy pressure. An oscillator swept each disc back and forth the way a hand would, and amp meters logged how hard the grinders were working. Every test ran up to 20 minutes or until the disc gave out, and results were averaged across multiple trials.
That gives us the four things that actually matter: how fast a disc removes material, how much material you get per dollar, how fast it removes per dollar, and what it really costs to run.
“I grind at home, on weekends, or on a budget”: The Weekend Warrior
Your time is not billable and you are not burning through a case a week. You want a disc that cuts well and does not cost much. The good news is that the best budget disc is not the cheapest one, it is the one that gets you the most work per dollar.
  • Steel Savage, $1.90. The winner. This is the disc to buy in this category. It had the lowest operating cost and the best material-per-dollar of any flap disc we tested, and it removes material noticeably better than the cheaper options below. The extra dollar or so over the bargain discs pays for itself quickly, because you get more grinding out of every disc. If you buy one disc from this list, buy this one.
  • Blue Sali, $1.35. A solid, cheaper option that still graded well on value. Fine for light or occasional use.
  • Benchmark Abrasives, $0.88. If you run fiber discs, this was one of the best-value discs on the board, and the lowest price of the bunch.
“I need to hog off material fast”: The Metal Mover
Big welds, heavy stock removal, and burning down an edge in a hurry. You care about how fast the disc cuts, not pennies per inch. These moved metal the fastest in our testing.
  • Walter XTRACUT, $2.39. On average, this had the fastest first-60-second grind of everything we tested. When you need to get moving right away, this is the one.
  • Kimball Midwest, $20.74. The fastest flap disc on the rig. It costs more, but if the whole job is about moving metal, it moves a lot of it.
  • Lehigh Valley Abrasives, $6.29. One of the highest total-material removers in the entire test. Precision-shaped zirconia grain that keeps cutting.
“I run discs all day and want the best value”: The Value Hunter
This is the sweet spot: fast removal and low cost, plus the lowest true cost once you factor in both time and material. If you buy by the case, start here.
  • Steel Savage, $1.90. The value story of the whole test. It had the lowest operating cost of any flap disc and the best material-per-dollar, and it is the thickest disc we measured at .55 inches, so there is a lot of abrasive to work through before it is spent.
  • CGW Abrasives, $5.73. A strong value pick that removes material quickly for the price. It does not reach the Steel Savage on overall operating cost, but it is a dependable mid-priced disc that pulls its weight.
  • Walter XTRACUT, $2.39. The best-value fiber disc we tested, with the lowest operating cost in that category.
“I do light-pressure, clean finishing work”: The Finisher
You are running lighter passes and you do not want a disc that glazes over and starts skating the moment you ease off. These held up well under light pressure in our 4 lb tests.
  • Hercules, $9.99. This one performed very well at lower pressures, staying productive when we backed off the weight. If most of your work is light and controlled, this is a strong pick.
  • 3M Cubitron II, $7.16. Its shaped ceramic grain fractures to stay sharp, so it keeps cutting freely without needing much pressure behind it.
“I just want to try before I commit”: The Sampler
Before you commit to a case of anything, spin a few up on your own steel with your own grinder. Our Combo Disc Pack is built for exactly this. It lets you run a range of our discs back to back and feel the difference yourself, including the standouts from the categories above.
Grab the Combo Disc Pack here: Combo Disc, Discovery Pack
The bottom line
If you are… Get this
On a budget or grinding at home Steel Savage, Blue Sali, Benchmark fiber
Removing material fast Walter XTRACUT, Kimball Midwest, Lehigh Valley Abrasives
Chasing the best value all day Steel Savage, CGW, Walter XTRACUT
Doing light-pressure finishing Hercules, 3M Cubitron II
Just trying things out The Combo Disc Pack
We did not guess at any of this. We tested it, filmed it, and charted it all out. Watch the testing videos, read the reviews, and dig into the full performance data, then shop with confidence.
Have a question about your specific application? Post it below and we will point you to the right disc for the job.
