Breaking The Fireball 510 Hardtail Vise
We just posted what might be our most extreme testing video yet, and no surprise, we didn’t hold back. If you haven’t seen it yet, click here to check it out! (video releases 7/19/25)
We dragged the Fireball 510 Hardtail Vise behind a truck,
Twisted pipe in it, pushed it with hydraulic cylinders,
And compared it head-to-head with two legends:
  • The Reed 205 – A vintage vise that sat on service trucks back in the 1920s. A symbol of “they don’t make them like they used to” engineering
  • The Snap-On 1765 – A modern day favorite, based on the classic Wilton design
We did this to find out what it really takes to break a vise.
We weren’t interested in specs or reputation. We wanted survivability and what happens when a vise is pushed beyond what it was designed for.
So here’s a full breakdown of the gauntlet, and how each vise performed.
Clamping Force Test
We used a torque wrench to apply 100 ft-lbs to each vise and measured how much clamping force that produced.
Results:
  • Reed 205 – 2,700 lbs
  • Snap-On 1765 – 6,200 lbs
  • Fireball 510 – 11,531 lbs
The 510 turns torque into clamping force like a monster. You don’t need a cheater bar just tighten the handle by hand and it grabs.
Pipe Twist & Lift
To simulate real-world pipe work, we clamped a piece of tubing and used a long lever to twist and lift it out of the jaws — like trying to unstick a rusted pipe fitting in the field.
This test was also done at two distances from the lever, 28 inches and 6 inches. Here’s what we found:
Reed 205
  • 28 inches: – 607 bs
  • 6 inches – 983 lbs
Snap-On 1765
  • 28 inches: – 651 lbs
  • 6 inches – 877 lbs
For this test, the handles on the Reed 205 and Snap-On 1765 were twisted until they were bent, ensuring maximum clamping force was being used.
Now we come to The Fireball 510 Hardtail. We gave this vise a huge disadvantage by only tightening with hand strength. No cheater bars, no bent handles. The jaws can also be interchanged with 3 different types:
Stock, Soft, and Pipe-V Jaws. So we tested all three:
Fireball 510
  • Stock jaws
    • 28 inches – 530 lbs
    • 6 inches – 990 lbs
  • Soft aluminum jaws
    • 28 inches – 380 lbs
    • 6 inches – 750 lbs
  • V-pipe jaws
    • 28 inches – 2,340 lbs
    • 6 inches – 2,623 lbs
The Fireball’s V-pipe jaws grip harder than anything else tested. And our soft jaws let you hold without damaging finished work.
Swivel Base Strength Test
Next, we locked each vise’s swivel base and applied torque 28 inches out from center using a hydraulic ram. Once again, the handles on the Snap-On and Reed were twisted until they were bent, applying the most force they could handle.
Results:
  • Reed – Slipped at 668 lbs
  • Snap-On – Base broke at 694 lbs. Inside the base, the locking teeth were flattened and the handle spindles were bent and twisted
  • Fireball 510 – Held strong at 1,886 lbs with zero damage
The 510’s wedge-style locking system flat-out works. It’s stable under real pressure, without bending or skating like the others.
Jaw Alignment Twist Test
And now we arrive at our final test, intended to break each of the vises until they were unusable. We clamped a custom steel frame and forced it sideways using tons of hydraulic pressure the goal was to simulate real field abuse and see what breaks first. We switched up the order and tested The Fireball 510 Hardtail first. This way, we could set a benchmark, and if the other vises could pass The 510’s limit, we would spare them.
Results:
  • Fireball 510 – Survived 43,829 lbs before shearing one bolt
    • Casting remained intact
  • Snap-On – Failed at ~17,248 lbs, with the dynamic jaw fully bent to the floor, and twisted out of alignment
  • Reed 205 – Shattered at ~12, 448 lbs, cast iron exploded on the dynamic jaw
The 510 absorbed more than double the load of either competitor and kept going. Neither the Reed nor the Snap-On made it past 20,000 lbs without becoming scrap.
After all that, we pulled the vises apart. Some were fixable. Others were just plain toast.
But the 510 took everything we threw at it including being dragged behind a truck at speed before testing and still outperformed every other vise in the lineup.
The Best Vise Ever Made
We designed The Fireball 510 Hardtail Vise to be a field-ready, high quality service truck vise, and after these tests, we truly believe its the Best Vise Ever Made.
But we want the world to know that too. So were asking you, The Fireball Tool Community, to help us spread the word. Post your experiences with the 510 right here under this post or make your own post. Talk about why you like the 510 on reddit, or anywhere else on the internet.
And if you like this video and want to see more:
  • Drop your test ideas here in the forum. We actually read them and use them to shape the next videos.
  • Want us to try rebuilding the broken vises? Let us know! We’re game if you are.
We’re not trying to make the cheapest vise.
We’re trying to make the last one you’ll ever need to buy.
Let us know what you think. And if you’re one of those folks who says “I don’t trust a vise until it’s broken a bolt or two,” well, we’ve got footage of that too.
And click here to get yourself a Fireball 510 Hardtail Vise or click here for its older brother The 614 Hardtail.
See you in the next test
Summary
Hi, J.
Dude don’t sully your good name by letting Snap on paste theirs over it.
You want it to be accessible? Get with harbor freight. They are making big moves in hopes of eating Snap on, Matco, Mac, etc’s lunch and they are making progress. I’m certain they would love to have a legitimate top shelf, made in the USA offering in their stores.
If they had been around with the level of tools they have now with their higher grade lines when my career was getting rolling I’d have been thrilled. I’m out of the game now, but there’s my perspective since you asked.
Snop On works closely with manufacturers and intermediaries on a regular basis.
Harbor Freight always cuts the middleman out of the picture. I think it is impossible to work with HF.
Snap On is a brilliant move, as they have a large and loyal customer base, along with a lifetime warranty and offer repair/replacement part services, which aligns with Fireball Tools principles!
Harbor Freight is known for stealing good selling product ideas. I know several tool companies that have had to fight harbor freight over patent infringements. They just take what they want. They will probably just make a very bad hardtail copy and take a bunch of shortcuts on the product.
If they came to the table and wanted to talk I’d be open to the conversation.
I hear you and have seen the same but at the same time it seems like they have been trying to shift their place in the ecosystem toward legitimacy. Maybe I’m fantasizing but I’m just trying to hold on to a bit of optimism as that gets more and more difficult.
We’ll see. Either way I hope your work makes its way to as many work benches and service bodies as possible. It’s good stuff.
Jason & team, great video. Thank you for creating a video such as this. I am a user of Fireball tools and inform many of our customers about your products.
At the 5:20 mark in the video, the Hardtail jumped in the force output reading from ~5,000 to ~11,000 as the camera switched views. In defense, you stated “it’s going up fast” as expected. From a consumer perspective of the video, it would seem that something changed with the changing of the camera views.
Disclaimer: I am not a content creator. My constructive criticism would be keep the camera view/angle fixed during the peak of a test. In my head I’m thinking of other product review channels that test to failure, and keep the camera fixed during the peak of product testing/failure. I do not believe Fireball was dishonest in the testing or filming, though I watched the output force section of the video several times to make sure I wasn’t missing anything.
The ending of the video was probably my favorite part. The discussion of how and where the Hardtail vices should be available. I have mentioned this idea before in other threads. Not just the vice, the squares, clamps, magnetic shims, C-clamp plyers. Don’t water down to the Harbor Freight level. You obviously understand their strategy for “tool design.”
Our line of equipment repair work takes us into all sorts of facilities. Many larger organizations have contracts with suppliers to use them exclusively for nearly everything, leaving Bob the shop guy with tied hands when he needs to order a product. He can only order from McMaster, MSC, Grainger, Fastenal, etc. I see this all the time, especially in publicly traded companies and government facilities. Having the Fireball tools available through those avenues would be monumental. However, you are correct at the end of your video. It will take us, the consumer, to make those request and push for better products to be available from those suppliers. I cannot imagine the level of difficulty you and the team face trying to promote your products to these large companies.
I will own a 614 one day. That vice will be in my family for generations to come.
Okay, back to work.
