It would be great to have a welding square that already has the holes in it to pin/bolt it to the fixture table so that it can be used as fixture as well. You could also connect them to each other to make larger fixtures. You can also connect larger squares together and make a flat surface to weld on and attach other fixtures on the back of if you can’t afford a fixture table yet(like me). This just adds options to an already versatile tool.
I totally agree. I have the DIY fixture plates and being able to use my squares on them as a fixture as well would be great.
Mr. Ford,
Genuine Metal Works has several sizes of squares formed from 1/4" steel on a press brake that incorporate slots and grid holes. Here’s a shot of them holding my small fixture plate from Roy Crumrine (Crummy Welding) adding a second reference plane for fixturing.
