Got a broken vise? We want to see it. (and you'll receive a special discount towards your New Hardtail Vise!)
@c17cuda Thanks for sharing, a code was sent in messages.
Refurbished an estate sale cross slide vise and got a years of use out of it with low impact use and drill press projects. Needed a specific action vise for a quick rebarreling job and the vice held things perfectly so I decided to give it a try. A 3 foot breaker bar on a massive tap wrench holding the barrel, and the vice went out with flying colors spraying chunks of cast junk around the shop. Seems to have sheared the nut for the vise itself, as well as the nut on the slide and bent the ball screw. Definitely in the market for something with a lot more strength!
@Ntbayerische a code was sent in your messages. Thanks for sharing
Our Wilton has finally had enough. The threads have gotten chewed up enough that it will only open about two inches and that is getting harder to do.
@bon Thanks for sharing. A discount code was send in your messages.
@Krbraulick Thanks for sharing. We sent a code in your messenger.
This vice has seen some years of abuse, it finally gave out with with a very tight swivel, missing 5 of the 6 jaw bolts, will no longer lock in place just free swivels and loosens up constantly. I ended up welding the swivel to my table (last photo) then I started to break my tools
Thanks for sharing. A discount code was sent in your messages
A Tale as old as time. Cheap Chinese vise that I’ve had for only a couple years but has been put in full time use lasted only a month before beating a pin out of a bracket cracked the stationary jaw! Luckily was able to get the job done but an upgrade is in order!
@sasquatchdab A code was sent in messages, it sucks when a vise fails right in the middle of a job.
My father is a hobby-machinist. He’s got all sorts of tools and metal working machines he uses for his own practice. Last month he was helping me build a custom mount for my boat dock. We had a bunch of pipes we needed to slightly bend, we heated them up with a blow torch and locked them in the vise to bend. Needless to say after many bends two grown men pushing on it cause the old metal to give out. I did some research later and found out it shouldn’t be used like that… So his birthday is around the corner and I’m looking to replace his vise with a new one.
He told me after it already had a crack in it so the shoving was the final straw for it. He also said how much he hates this vise becuase it never holds its position and shifts on him. So he probably is due for replacement anyway. Still need to get his concrete fixed from the large chip where the jaw fell.
Yikes, thanks for sharing your story and a great birthday gift indeed. A code was sent in messages.
My little Scout vice gave up the ghost while I was hammering out some old rivets from an AK parts kit. The swivel base cracked and flexes with any force applied, and the vice itself lacks a better way to mount it without the base. Now I’m in school for machining and I need a real vice! Have enjoyed your content on youtube and thanks for the great forum!
Wilton Vise stripped out the threads
Thanks for sharing a code was sent in messages.
I was working on a personal project for my friend, his dog of many years passed away and I made an aluminum cross for his burial site. I was pretty gently wrenching on the vise and the ring for the swivel snapped and shattered in at least 4 places. The whole vise fell and made a nasty chip in the floor. Definitely looking forward to a high quality hardtail vise.
The Wilton bullet swivel base is very weak. It’s been a known problem since the design was introduced 70 years ago. If you look at the casting it’s paper thin. I’m not sure how Wilton has gotten away with the weak design for so long. Most of the used Wilton bullets the swivel base is missing because of this reason.
We designed the swivel base on the Fireball Hardtail to be practically indestructible. We test it with our 100lb hammer. It’s also an anti theft with the correct fasteners. Message was sent for a discount code on a Hardtail vise.
Old columbian 504 finally bit the dust ready for a new one
Code sent in your messages
