Movement in tables with tower blocks
Hello, I am looking into getting a fireball table or tables to use in our fab shop. We deal with a lot of structural steel with beams between 4-14” and plate steel 3/16”-1.25” just to give a range.
I do not know what table would be best out of the heavy duty 13’x6.5’ or getting 2 standard duty 8.5’x4.5’ tables and using tower blocks to space when needed.
Does anyone have any experience with using the table and tower blocks with heavy material like this and having any issue with flex in them?
Both the Standard and the HD will be up to the task, but the HD will take anything you can throw at it. The extra thick material on the HD was designed for heavy structural steel.
Thank you Jason. How do the tower blocks handle with flex when they are used as extenders between 2 tables?
No issues, the towers are hard core heavy duty.
