Is a bad idea to ground through the table and into the work. Any gap in between the work and the table will start to arc and erode the machined table surface. It’s a good idea to ground directly to the work to ovoid this.
well, thanks for getting back so soon. Good To know, I didn’t know you would mess with your finish Table. Because on my T slot table, I ground right to the leg and everything‘s very well connected.
It was nice talking to you, Jason. I learn a lot from your videos.
And I have 1 more question did you ever return those frames to those businesses to get your money back? Since they didn’t meet the specs and pass inspection?
Please let me know I’m curious
No I was never going to return them.
Heres some things you can do with your shop press to help save time and make things consistent
- Put a little knob on the release valve so you dont have to take out the lever bar and wedge the bar into it every time
- Get a pressure gauge installed in the jack, that way you can jack it up to a repeatable force for unbending all 8 of your T joints for instance rather than just counting pumps and winging it
Thank you for your pursuit of excellence, your determination to evaluate your work along the way, and your excellent teaching skills. I am new to metal working, and especially to using a fixture table. I bought one from you as well as tooling and I am trying to learn to weld as I learn the table/fixtures. I do have one question: What diameter flux core wire are you using as your build the square tables? Are the large fixtures you used for all four sides of your table expensive? what are they named? Tks, Larry
