Any plans on coming out with a 1/32" tooth washer?
The problem is the physical manufacturing of such a small tooth. I’d wish it were possible, but not at the moment. We have a clever solution in the near future.
Can’t shift the holes from the teeth? Isn’t that what you did on the 1/8" to 1/16" washer?
No it doesn’t work like that. The teeth are 1/8 apart. You would need 2 separate 32nd tooth washers to make that work.
Just use the 1/32" shims. Set the block 1/32" less than what is called for (which will be on a 1/16" tooth) and then use the shim. I had to do that with 1/16" shim because I hadn’t ordered the 1/16" washers yet.
