18x8x8 tower block compatibility question
I see (and love) the new tower blocks)
**FA75-CTL183 and / FA75-CTL182
I was just wondering if they were compatible with with the G series 54"x"12"x8" tower block as legs. Its unclear from the drawings. i want to use them as a leg for that big block and would want 1 corner the line up properly.
Yes they are the same bolt pattern. The towers will bolt right up.
I assume I would want the corner block? or is there a orientation where the center one would line up on 2 sides as well.
You’ll want the center leg block. It has the correct bolt hole layout to have the tower and riser faces to be complainer. It’s also more versatile as a tower fixture because its 5 sided
