De-Sta-Co side pusher/clamp
I wanted to share something I came up with last weekend for my fixture table. Many of you doubtless know about De-Sta-Co clamps and latches, and their use in fixturing. I wanted to adapt some for use with my Pro table. I used some off-brand generic ones, but they are supposed to be copies of the #603 clamp. I made this out of some 1x2 hot rolled bar stock left over from other projects.
After bandsawing to rough length and cleaning up to overall dimension in the mill, I started by center drilling the top where I wanted the peg to be, and then milled down to a thickness of .25" leaving an oversize squarish area in the middle around the center drill. Drilled and tapped the holes for the clamp and for holding the adapter to other FB fixtures. After that, I moved to the 4 jaw chuck on the lathe, and using the center drill spot I indicated the block in with a dead center and the live center in the tailstock. Then turned the square peg into a round one.
I didn’t make this in two pieces like the FB fixtures, because I wanted to minimize the amount that the adapter raises the clamp over the table surface, or that of the fixture it is mounted to. The peg is a little shorter than I would have preferred (which is why I left the hot rolled finish there, to maximize its length) although it is more than adequate strength wise. If I’d had thicker material to work with, I would have left the drilled and tapped portion at 5/16" thick. This would let the standard length 1/4-20 SHCS that Fireball includes with their fixtures work with it. For these, I am going to mill the underside of the clamp slightly for clearance with the screws so I don’t have to use shortened screws.
This is the clamp on the table, mounted with 10-32 SHCS. The end of the clamp ram is threaded 5/16-18 2" deep, although I am using a 1.5" screw there now because that’s what I had. But there’s lots of adjustment available there.
In use with a 6" riser on a tooth block. I think this sort of arrangement would be particularly useful for repetitive loading and unloading and making multiple parts. IIRC the clamp is rated at 600 lbs of force.
Anyway, I thought I would put this out there in case others might find it useful. It was relatively time consuming to make using manual machines, especially for me as a relatively inexperienced machinist. I am going to make one more and that will be it unless I find myself needing more for some reason. I have zero interest in making additional units for sale, so please don’t ask. If somebody so-equipped wanted to run with it, it would probably be a 5 minute part for a CNC machine.
