I built a web tool that automatically makes fixture maps for Fireball tables
Start with My Shop. Enter how many of each fixture component you have. The generator only uses what you’ve got, so every map it makes is one you can actually set up in your shop.
Then import a DXF or STEP of the part you want to fixture and pick your table. It auto-places the fixtures and prints a map with hole IDs, tooth block settings, shims, and a BOM. You can also manually place fixtures if needed.
Please note:
It’s vibe-coded with an AI assistant. I’m not a professional developer, so expect some bugs.
I don’t own every fixture, so some dimensions are unverified if I couldn’t find CAD for them.
Check every map before you weld. It’s a starting point, not gospel.
Free, no account, no download, nothing uploaded. Your data stays in your browser.
Feedback welcome: maps that look wrong or fixtures I’m missing.
This is just a little personal project, and I hope some of you find it useful.
