HD Table and DW
Quick question, I looked but I didn’t find an answer.
Do the accessories for the 30x54 dragon wagon fit the 30x54 HD table?
I purchased 2x of the 28" cast extension blocks. I think I would feel better hanging them long ways on the HD table, then the DW.
I did purchase the 24x36 dragon wagon a few weeks ago. In really love it but in an effort to save money it’s ballooned anyways. So I was thinking about adding a 2nd table. If I get another 24x 36. I feel like I will regret that too. So I laid out some options. I like the idea of the 30x54 making almost a box with a relived corner.
I even thought about 2x of the smaller DW with my 2x 28" ext in-between making a 36 x 72. But I feel that will just have me buying a few more ext’s.
But I’m already so deep, I was thinking of just doing the HD version. It’s cheaper to do it now then later.
The legs on dragon wagon are the only legs that will work with the dragon wagon accessories. There are accessories for the other tables in the pipeline but they are not interchangeable.
What if I put the dragon wagon legs on the HD table? @Fireball_Wyatt What is the weight on the 30x54 HD Table?
The bolt patterns for the legs are completely different so unless you intend to drill and tap holes for the smaller leg they do not work. The only real upgrade you get going up to the HD table is the extended sidewall, I would recommend going with the dragon wagon if you are going 54x30 or smaller and I would say if you want to go bigger get into the standard duty tables. the HD tables are only for really heavy duty aplications.
