Question about jib crane build
I was wondering if you have a more detailed video of the base tapered roller bearing setup you used in the I beam jib crane build? I want to build a much smaller version for my 40 foot container shop and want to have a tapered roller bearing base.
I’ll have the guys go through the original footage. That crane built in early 2018. It will be Monday the 23rd when will get a chance. I’ll see what I dig up. Maybe a bearing part number or something.
Thank you Jason! By the way I am a repeat customer of Fireball Tool and will continue as long as you keep making quality innovative tools and fixtures!
I found the bearing part numbers that we used.
Top ceiling bearing UC213-208 this was 4bolt flange
Bottom
Timken LM1049L9
I machined a custom bearing holder for this that used a big bolt if I remember correctly.
