Shim cases
Has anyone found a case for shims that looks similar to the fireball cases that can hose more shims than the smaller case that’s offered?
I ended up ordering the 28 pc kit before the larger kit came out and has since ordered every shim that fireball offers. With all the shims I now have, I have exceeded the capacity of the smaller case.
Fireball sells a empty case to put the overflow shim into.
I think you used to offer a case only option but it has been removed from the fireball site
