Can I mount a side kick vice to my homemade jig table. I made this table 30 yrs ago from 25mm plate. Is has a 16mm hole drilled every 100mm. The plate over hangs the base which is made from 75mm angle iron by 30mm. I was going to purchase the spacer then machine the back of it down to 30mm.
Will this work?
