Check out our newest Fixture Fundamentals episode where Jason continues working on the Sci-Fi Office (specifically the railing) and uses the opportunity to teach his son how to fabricate. It’s chock-full of bits of information that even the most veteran fabricators may appreciate.
Leave your thoughts, questions, and comments here!
Great video, brought up some good points that will help out someone new to welding.
I have a couple of questions for you about some stuff I saw in this video.
I see you used two tacking bolts on the tooth block instead of one tacking, and one alignment bolt. Is that just because you had plenty of tacking bolts available so you might as well, or was there a specific reason that you used two?
When putting tacking bolts on the 1/2” thick Dragon Wagon table, you used a spacer. I have a 1/2” thick table with 5/8” holes and it doesn’t seem like I need spacers. Is that just a 3/4” hole size thing, or am I better off using spacers for some reason?
Great questions. One tacking bolt is all that’s needed to hold the fixture securely. Another tacking bolt or pin or bolt, can be used to prevent the fixture swinging. We just happened to use 2 tacking bolts this time.
Spacers are needed for the crossover between the 1/2 to 1in thick fireball tables. This prevents you from needing new bolts no matter the table thickness.
Generally 5/8 tables are around 1/2 thick so we designed our 5/8 fasteners length for 5/8-3/8 material. A spacer isn’t required if the bolt is clamping.
3/8-5/8 thick material is the bolt range with the FB 1” thick fixtures. A spacer can be added for thinner material tops. All the specs are on the FB website.
