We need a “master fabricator add on kit”
I got the 500 kit with my table and am constantly running out on my bigger jobs. When I fill up my shopping cart with a wish list I realize that I can get the basic stuff with a smaller kit for a better price but I don’t need some of the parts since I already have the deluxe kit.
A kit with a handful of basic fixtures, a bunch of cool fixtures not in the other kits and some of the new clamps would be perfect. Target price $3K to$4K
Make a list of fixtures and quantities that you would like to see as a new kit.
How does this look, let me know from your experience if it should include anything else or if I may have the quantities wrong
Tooth Blocks & Washers
- 4 – Tooth Block Kit (Tooth Block + Washer)
- 4 – Tooth Block, 5" mini (Tooth Block + Washer)
- 6 – 1/16ths Washer, For Tooth Block
Twist Blocks
- 4 – Twist Block, 2x2 Pattern
- 4 – Twist Block, 4x1 Pattern
Fence Blocks & Pins
- 1 – 5" Adjustable Fence Block (4-Pack)
- 2 – Stepped Fence Block (6" x 2" x 1"), EBS
- 4 – Fence Block (4" x 1" x 2")
- 4 – Fence Pin Blocks (6" x 1" x 2")
- 2 – Post Pin, 1" x 2" (4-Pack)
Extension Blocks
- 4 – Extension Block, 13"
- 4 – Extension Block, 6"
- 4 – Extension Block, 3"
Clamps & Vises
- 6 – Double Gooseneck Clamp
- 4 – Double 90 Gooseneck Clamp
- 4 – Twin Pin Plier
- 1 – Sidekick Vise (Standard/Heavy Duty – 6" & 8" Sidewall Tables Only)
Bolts & Tools
- 6 – Connecting Bolt, FA75, 2" work length
- 2 – Tacking Bolt, Standard Length (4-Pack)
@Juskos is this a kit where you see it as the ideal for a first time buyer?
Looks pretty interesting, and I see you included a lot of newer items that came out after.
Yes, to add on to any of the larger kits as an expansion pack.
