Fixtures......in the future
Jason,
Do you feel that you have created all the fixtures necessary to do the job or are the other types/styles of fixtures on the drawing board?
Don
Not even close. We have lots more fixtures coming down the pipeline.
Got anything that will work for bicycle frames or round tube work in general?
How about a tooth block protractor doing 90° and 45° very easy I’ve been doing lots of other degrees with only one tacking bolt to hold tooth block
This does 45
Yes sir it does I own them. Now let’s configure 30° or anything other than 90° or 45°
This is the proper procedure for setting angles on a fixture table. How do you like to fixture angles other than 45°?
Angles are set with 2 tooth blocks. This is a better use of tooling and accuracy.
Came out to shop tried it just a little bit off 60° on the table now. Maybe with the 1/16 inch washer
Yes the 1/16 is very useful. Also you don’t have to use the washer if you don’t want.
You make a magic square, how about a magic tooth block or fence block protractor?
