Here’s a first look at the new DIY fixture table plates. Were currently offering them in 3 sizes. All the plates are 1/2 thick steel, ground flat, with machined holes, chamfered on both sides, Dragon scaled for extra plate protection with adjuster grub screws for plate adjustments.
You can purchase just the plate and build a frame and legs that suit you the best. Or we offer an economical leg and frame kit that has all the material pre cut and bead blasted. The hardware includes the frame straps to secure the 1x2 to the plate without welding. Also included are basic feet, and optional leg braces.
The idea behind this simple frame is to keep the cost low and functional. We all know that I tend to overkill all my designs. You can also combine plates together with this frame style if you desire.
The flatness is unreal! This kit puts most of the machined tables to shame. Don’t be fooled by it’s cheap price tag.
I’ll be doing assembly videos to show some simple tricks to get the tables put together fast. Along with a plate calibration “How To” video.
[/grid]
54"x 54" 1920.00 with frame and leg kit
30"x 54" 960.00 with fame and leg kit
24"x 30" 575.00 with frame and leg kit
