I’ve been been told the multiple times that new vise owners are replacing the hardtail vises original engineered handle for a longer solid bar. Is there no trust in the original handle to help the vise perform at peak performance? Jason
Not sure. Came here to purchase this new vise but it appears to have been discontinued? How come??
@Rufus Due to the high demand for the Hardtail vise it’s only available for pre order. Basically 100 bucks reserves your place in line when a vise becomes available.
Thanks Jason, any estimates on when they will be available? Are you going to ever make that tilt plate available for this vise? I cant figure out if that would be a good addition for a vise or not?
@Rufus We expect to have vises in stock this fall. The tilting base is planned for production. It normally takes a year for it to be ready.
Will the tilting base be similar/or the same design as you made it in the youtube video? I have a fixture table with 4"oc/28mm holes, and I would like to bolt the tilting base to the edge of the table.
Jason, are both balls threaded onto the bar, or just one side? Not needing to change the handle for length, just thought about replacing the ends with something a with a little more girth.
Only one side is threaded.
Some people probably think more=better. Some people might not not be as strong, older guys and people with disabilities, and might want to be able to put the same pressure as someone strong and extra leverage will help get them there. I do have to admit a longer bar does feel nicer, and you don’t have to yank as hard. I’m sure others will though.
I hope you not changing it a lot. I really like it and plans on buying
one when I’m able I think this would be the last vise I would ever need. I really like when you showed how strong
the vise was and the torture that it took. I have plans to get one one day nice job Jason.
Would it be possible for you to add a spring loaded ball bearing in the back center of the spindle that would “click” into a groove in the middle of the handle to hold it centered for fast turning?
