Bolts for dragon wagon
Just got my table legs and accessories. Super excited for sure during assembly of the trays I was surprised that the box with the trays didn’t include a full set of new bolts for at least the bolt locations that require the spacer. Also side note I watched the video where Jason punishes these tables and I know he had full thread engagement to ensure striped holes weren’t the cause of the leg failure. I’m going to do some simple math here.
Supplied bolts are M12x30. Then we have a spacer that’s 9mm and a washer that’s 2.5mm call it 3 mm for simplicity and two brackets to hold the trays in place 4.5 mm again call it 5 mm for simplicity and the leg flange oh yea can’t forget the leg that just shy of 10 mm and you have a table that rolling around with a dry weight of 450 lbs with ? mm of thread engagement. I’ not mad I just can’t believe that 3 mm of thread engagement is ok for something that’s this heavy and your going to add weight to. My mind says that there should be at least 2 times the diameter of the fastener of thread engagement. I really don’t mind that the bolts that were supplied aren’t socket head cap screws. But for gods sake they need to be long enough to properly handle the recommended 30 ft lbs of torque. So in conclusion there are three bolts along each short side that are compromised and a total of 4 more on the long sides that have slightly more thread engagement and at the end of the day your left with exactly 1 (ONE) bolt that has slightly less that 20 mm of engagement to keep the whole system honest.
elane17
Which dragon wagon did you get, the 36"x24" or the larger one? I got the former and I know that mine came with socket head screws (though they weren’t the right threads and had to get replacements). I bought washers with my replacements (they credited me for it) and I know that I was seeing the thread issue you are talking about when I was recently installing my slag trays. However, I then noticed that on the pictures of the table on the site, it doesn’t look like there are any washers. I took the washers off and then it was all good for me. There are differences between the different dragon wagon table sizes though so it may be different if you got the bigger one.
Yea I got the bigger one 30”x54”I will place an order for a care package form my local bolt company that will clear this all up it seems that this should no longer be a issue for something so simple.
elane
@elane17 our CS team will reach out to you
