Dragon scale durability
How does everyone’s table look after some use? so far I have used mine twice ( trying to set up my little home shop ) and looks bad. I did have issues from delivery and arrived with dragon scale defects and marks, and rust.
from what I can tell dragon scale is meant to be heat resistant right? I have a het mark from a single weld, not directly done on the table surface and still the residual heat of the weld has left a horrible mark on the table.
would love to see pics of everyone else’s tables to see how they are holding up
Did you clean it off? I see heat marks and things like that right after welding but when I spray it with some WD40 and wipe it down, it goes away.
This was the first time I actually really used the table. I spent maybe 30 mins on a small jig. I did indeed try wd40 with a cotton rag. However this started to take the black coating off.
Hmm, that’s odd. I do the WD40 and use a microfiber cloth on mine all the time. I do notice that there are color variations and it can look different colors whether it is freshly used, wiped down with WD40 and still wet, or after it has dried. If it isn’t something simple like that, there may be an issue with that specific table coating. If that’s the case, I would reach out to support as they are good about getting things resolved.
Yeah I was speaking to Jason and seems my table isn’t right. Hopefully get it sorted soon :slight_smile: thanks for your help too
I had a wife like that. lol
