We recently purchased a Dragon Wagon fixture table and are trying to assemble the accessories but ran into an issue with the long brackets for the slag tray. The stamped mounting hole that reaches to the back of the table appears to be in the wrong location and does not line up correctly. I tried searching the site for CAD files to verify this, but could not find any for the bracket. Attached are pictures of the bracket with a tape measure for reference. Is this a manufacturing error, wrong part, or am I completely missing something here?
The rear hole is in the wrong location it should be 25" to the center of the slot. Contact @CustomerService and they will get you set up with a replacement bracket. In the mean time you can drill out the hole at the above mentioned dimension so you can use your slag trays until we get you a replacement part.
Fireball customer service is outstanding!!
