Fixture table build…the hard way
You’re saying that you used the fireball template but have a discrepancy in different axis or the far end of the table? I noticed that my template does not line up when laid across the length of the table. So 90* to the orientation of how they were drilled. The fence blocks will fit in either axis across 2” but not the template across 28”. There must be a slight error in my template.
And a cool progress shot. How the table and fixtures can aid in their own construction. I’m impatient and tired coming off a night shift and not sure how much I want to dial in the accuracy of the weld joints. I figured two wrongs must make a right so I bolted the satellite table to the primary to pull everything flat and began utilizing the tool system
