How to best to keep your work straight/flat/plumb?
Most of the things I build are cube-ish frames, made from 1/8" thick angle iron. These typically are formed by 12 pieces cut to length, and then 45s cut into both edges of both sides. I use a Dragon Wagon and (Table Kit 2) fixtures to secure the material to the table. I’ll use a pair of 1" tall shims under each piece of angle, and use either a Quick Clamp or a Swivel Plier to hold it, pressing down exactly over top the shim under it - to prevent bowing. For two of the sides, I use a pair of table blocks (positioned oppositionally to prevent block lean). The other two sides are held in place with Extension blocks/Tooth Blocks for the additional adjustability - always with at least one tacking bolt to ensure fixture rigidity. I’ll tack these 4 pieces together as the top of the cube, allow to cool, then repeat the process with the next 4 pieces to form the bottom of the cube. I’ll clear out all the fixtures and redesign the layout to allow the top form to sit fixtured to the table upright, the bottom form will be set in a mirrored stance across from it, and I set in 2 of the 4 “stringers” that connect the Top and Bottom forms. Tack, allow to cool, then rotate the entire form 180 degrees so I can attach the last 2 stringers to form my cube.
This works pretty well at tacking the cube together. Most of the time, I can take my completed cube, place it on empty table, and try to test for flatness and I’ll get no “teeter-totter” (probably a better term for it) on any of the 6 sides.
Then I go to actually fill in the welds and all bets are off. Using as many fixtures, shims, and clamps as I had in the kit, I always seem to warp. I’ve watched Jason’s videos about the order I should do the welds - and followed it - but its always seemed that I’m short on clamps. I recently added four 13" Extension blocks, plus 6 C-Clamps, and 6 or so locking C-Clamps. The form gets so busy with clamps everywhere that even a 20"+ cube gets a crowded and tough to get up inside with torch and helmet on.
Going with idea to try to have 2 clamps on every surface (in other words 4 clamps holding each piece of angle) to 2 immoveable plains (table and fixtures) seems to have helped. I’m also allowing some cooling (not very scientific with my testing here, but when a laser thermometer says no point of or around the weld is above 130 degrees - that’s cool enough) before I remove any clamps. In this cube scenario, I’d have 4 table blocks and 4 Extension blocks positioning the cube on the table. 8 one inch shims between the cube and table, with Quick Clamp or Swivel Pliers holding them in place.Now I can add two 13" Extension blocks to 2 of the 4 lateral sides of the cube. I’ll clamp the “stringers” to the Extension Blocks in a high and low spot. Each corner will need a total of 4 beads I need to weld - going from center out. I’ll do one corner, then the opposite corner. Once the laser thermometer reports the hottest weld is down to 130 degrees, I undo clamps and flip it. Once I’m done, I’ll grind down any weld that may have fallen through a gap - or is otherwise exposed to the outer plains of the cube.
Even with these extra clamps, I’m still not reliably creating cubes that are as straight/square/flat/plumb as I would like. Still a little teeter-tottering.
I’ve only got about 5 years experience as a hobbyist - so I’m sure my form or method can be improved. If I need to add more clamps to these forms, IDK how I’d be able to get up inside the form with a helmet.
Any experts have some free advice?
Film the work and upload it!
What you are describing is your perspective, and it may not necessarily reflect what is actually happening.
Can you share photos? Or upload a video? What tolerance are you trying to achieve? How large are your gaps between the material? Does the weldment require all the welding? Can the amount of weld on the joints be reduced. Example: limit just exterior joints to be welded? What welding process are you doing?
Also welds will continue to shrink until the temperature is low enough to hold your hand on the part continuously. I’ve done tests on this.
I’ll make a video that’s as brief as possible, showing the stages of my build. Answering your other questions in order:
I don’t have a numeric answer for this - it’s my personal preference for my start up business. I’m happy when I can place the form on my DW and not feel any movement. I have a shim kit, I’d estimate that 1/32" over say 2’ would be my max.
On a bad cut - I could have a 1/4" gap. Typically the gaps are 1/32 to 1/8.
I don’t know how much actual welding each weldment really requires. These cubes serve as a frame/structure that’s covered with wood, secured to the frame with screws. Some of these cubes have a tall post going up through the middle (and additional steel/welds to hold it) that supports a small amount of weight. I’ve never studied mechanical engineering, I’m sure there’s math to determine the load and force that will be applied to my cubes, but I’m ignorant in how to make those calculations.
Probably. My worst fear is that I build one of my items for a customer and a weld fails. Feels like that could ruin me before I even really get going. All of these welds are exterior joints.
I have a Hobart 140 Handler MIG welder, running .030 solid wire and Argon/CO2.
I’ll keep that in mind and let everything stay clamped until it’s down below 90 degrees.
Pics will help a lot or a video
if you have a 1/4" joint you need to cut more material and get it down to 1/16". If your trying to fill a 1/4" gap your are introducing a lot of heat.
Maybe your doing more welding then whats necessary. I would find out how the part gets used.
Are you getting drawings from the customer?
I have a customer that does mostly wood working and they have metal components that they draw up all the time. Most times they have things way over built for the application.
I think welds breaking are at the bottom of your list. If you feel that’s possible maybe you need to get better in that area first.
Maybe welds are the first place to start?
Before I had the chance to build another one of my typical angle iron cubes, I had to build a different one using 1/2" x 1/8" angle (I don’t recommend, ordered by mistake). Anyway I used Jason’s recommendation of allowing more cooling time, plus I added fixtures and clamps closer to the joints and my form stayed much more straight/flat/plumb. I’ve also started grinding chamfers and welding on the outside of the forms instead of tacking and the welding the insides.
I need the outside to be flat, which is why I was welding the insides initially. With a small gap, and chamfered edges, I have plenty of weld to join the two pieces, even after grinding flat.
Thanks for everyone’s help!
Jef I think the best way to keep things square, plumb, level, or on a particular angle will require tooling. However, restrictions from clamping forces will alter the behavior of the experienced distortion you seek to control. On .120" wall a fixtured weldment may limit expansion from heat in one direction, but as it cools back from liquid to solid those shrinkage stresses still exist even if the clamping force is trying to stop physics at the molecular level. Maybe the result is .020" shrinkage (say a box cutter blade thickness).
I uploaded several videos on distortion and flame straightening to this forum. Perhaps look them over when you find them. Jason’s comments/questions about weld size and preparation are valid. Larger amounts of weld deposit mean more shrinkage stress. Preheat, speed cooling, flame straightening can manipulate the results.
