Issues with new Evolution S355MCS
Hi all,
I have issues with accuracy and have narrowed it down to the Fences not aligning and the rotating table being higher than the base. Evolution sent me new fences and that didn’t help. I ended up coming up with my own fix.
I got an email back from tech support that said the frame on the right side of swivel base was lower on purpose so jambs would not occur…that is fine except mine in low on both side.
I have linked 2 videos to show what I am talking about. I have a replacement coming from Amazon and want to know what is normal and what isn’t.
Are any of you experiencing the same thing?
Mine is pretty straight. Maybe .010- .020 low on the right side.
and not low on the left correct?
This is what they told me about it being low on the right…from what I can tell the left is suppose to be level with the rotating base. My left side is .015 at the right side of the left fence and is .053 and the left end of the left fence.
Correct, the left wing is coplaner with the center, the right wing is tipped slightly lower.
What if your left handed and load the saw from the right? Or do left handed people load from the left?
A bit off topic but can you please tell me the diameter of the holes in the picture? I’m thinking about buying this saw and it would be great if my 16mm fixtures would fit :+1:.
Would you recommend this saw for a 1 man metal shop?
Thanks
They are 3/4
