I recently purchased a Dragon Wagon 54" x 30" table with Tool Kit 2 and am loving it. This week, I was setting up a fixture using a Tooth Block combined with a Stepped Fence Block to create a reference point over my workpiece for indexing on some pins, but things weren’t lining up.
After some troubleshooting, I checked the fence blocks and noticed that one of them was out of square to the Tooth Block it was screwed to (see photo). I removed and reattached it, making sure there were no metal shavings causing interference.
Is there anything else I should check to correct this? I don’t want to assume something wasn’t machined correctly, since everything else with this table and the fixtures has been perfect. But maybe I just ended up with a bad fence block?
And just to share, here is the project I purchased the table for and have been working on https://makeratplay.com/projects/63/index.html
