Pipe/Dom tubing
I primarily weld pipe and or Dom tubing (or round metal lol) being as I am a motorcycle builder. It is hard for me to find clamps or jigs etc (I usually make my own) any advice?
Do you have a fixture table?
No sir I do not. I have jigs built on motorcycle lifts etc, my shop is small and fixture table space is not applicable at the moment until I get a bigger shop. I’ve been thinking of getting a 1/2 or thicker sheet of steel and maki g a fixture table top for an existing work area.
Do you have specific applications for fixturing, I’m sure you do. Maybe post a photo
of an example and it would be easier to suggest a solution
I weld on al lot of oil field pipe , so the idea of squares for pipe would be awesome, but having to buy and store a whole nether set of squares seams expensive. What about a “pipe adaptor” that can bolt to your existing squares using the threaded tab holes? machined flat back to mate with the existing square and a V block type of set up on the other side. hopefully cheaper and takes up les room in the shop?
