Today I had a tacking bolt become stuck in the hole. In the end i needed to unscrew the set screw in the retaining collar after i removed the plunger screw and push the bolt through the table. Upon inspection one of the ball bearings had gotten stuck in the hole. I do not yet know if this will be a all the time occurrence and it only happened to one bolt but I may need to adjust this tool if it happens again. Has anyone else had this happen? if so did you do anything to address the issue?
Just give us a call will make it right
