We Lined Up Every Fixture Table in the Shop and Let a Real Crew Decide
If you’ve ever shopped for a fixture table, you know the problem: Which one do you buy? There’s no store you can walk into where you can see every brand lined up side by side. Best case, you catch a couple at a trade show, and even then, you don’t get to actually use them side by side. So you end up guessing which one is best.
Those were exactly the questions a local company called “Taylor’d Containers” brought to me. Which one do I pick? Why do they all look the same? Why are there so many brands? And why does everybody use a different hole size? Instead of answering with a pitch, I set up a real demonstration in my own shop, handed the crew a real project, and let them figure it out with their own hands.
Who are Taylor’d Containers? And why “close enough” doesn’t cut it!
Taylor’d Containers builds mobile training centers for firefighters, the rigs crews climb through, drop out of, and beat the snot out of to train for the real thing. Taylor’d has this one part they mass-produce, and that is a bailout window. A simulated second-story window that a trainee uses to practice exiting an opening. Every bailout window has to be built the same. Not close, not almost. If one gets destroyed in training, the replacement has to fit perfectly and behave exactly like the original.
What struck me was that everyone in the shop was staring at the same problem from a different chair. The owner wanted speed and cost parts out the door faster, less rework, right the first time. The shop manager wanted a repeatable process he didn’t have to reinvent every job. The engineer wanted parts that match the print and QC that’s simple and reliable. And the fabricators just wanted tools that work with them: less tweaking, less pulling tape on the same dimension over and over.
To boil it all down, they were asking for the same thing: build it fast, build it right, and never build it twice. The table they have is a 5x10 plate steel table that wasn’t quite flat, so they shimmed every part up and could only clamp around the perimeter. Four hours to weld out a single frame. If you’ve spent time in a fab shop, you’ve been there before.
Plate steel vs. fixture table
One of the crew members asked the right question early: What’s the actual difference between plate steel and a fixture table?
On a plate steel table, you cut your material and assemble it piece by piece, trusting every cut to be perfect. Small errors stack as you go, and the finished part drifts out of spec. A fixture table works the other way around. You set your stops and locators first, building the exact geometry you want, then drop your cut parts in and force the material to conform. It absorbs cutting errors instead of compounding it, and that’s what makes parts repeatable.
To test it, I split the guys into three groups and put each on a different system: a metric 16mm table, a system 28mm, a Build Pro 5/8, and the Fireball tables. Then I let them build.
The problems showed up fast
Here are some of the issues that the Taylor’d Containers crew were noticing when trying to build this bailout window part on different tables:
The part was bigger than the table. Every group was on a 4x8 table, but the window was 54 inches wider than the table itself. Material hanging off the edge sags, twists, and pulls a project out of flat. Everybody had to improvise support, and you could watch the cheaper extensions flexing from across the room.
Metric and imperial don’t play nice. One team couldn’t get their bolts to seat, turned out it was a Siegmund, and metric tooling won’t cross over. A 5/8 bolt drops into a 16mm hole, but a 16mm bolt won’t go into a 5/8" table. Worse, we found “imperial” tables that are really just metric table fixtures redrilled for a different slot length. The fixtures are still 30mm wide, so referencing face to face lands you on 8 ⅞” instead of a clean number. You can’t trust the side of the fixture, which defeats half the point.
Proprietary tooling turns into a hostage situation. Siegmund’s bolts go for about $85 a piece, and one team ran out mid-build. Why a 28mm bolt for a fingertight, temporary connection? Because they’d rather you call and order more than reach for a regular fastener you already own.
A box of Legos with no instructions. On the plate-pattern tables, all you get is a bin of fixtures. There’s no built-in way to verify one stop is square to the next without pulling tape every single time. Want to replicate the setup tomorrow? Re-measure everything and hope it lands where it did before. As one of their guys put it, you’d practically need a foreman babysitting every table.
Taylor’d’s work around process is that they were fitting tab-and-slot, old school, placing material first, and building the fixture around it. That only works if every cut is perfect, which never happens in the real world. The CNC hole in the table is more precise than the part. So build the fixture first, set your geometry, and let the material conform to it.
Where it all changed for the better.
When the crew moved onto the Fireball tables, the mood changed. Every hole is individually labeled with an XY coordinate, so there’s no squinting at a perimeter scale that resets every three inches, a design choice nobody in the room could explain from the other table companies. The tables run slightly oversized, so parts aren’t dangling in space. The fixtures are compact, modular, and interchangeable, and they work across the entire lineup, so stepping up to a bigger table doesn’t mean starting over from scratch. There’s one bolt with spacers instead of a drawer full of proprietary lengths, you can get 4 Fireball bolts for the price of one Siegmund bolt, and you can make your own stops out of bar stock if you want to, with the Fireball table system. The Fireball tooth block also positively locks material so it won’t pivot under pressure.
But the thing the engineer got most excited about wasn’t just a fixture at all; it was the fixture map. He builds it straight off the CAD model onto a scaled drawing of the table, and the fabricators just read XY coordinates and drop the tooling in. It confirms you actually have the parts in inventory before the job starts. It caught their tab-and-slot cut errors before the parts ever reached QC. And it finally bridged the office-to-floor gap that had nagged them forever. In their words, QC goes from a bottleneck to a formality, and they can finally trust parts that a newer fabricator built.
By the end, Fireball came out on top for them, and we only scratched the surface. We didn’t even get into flatness tolerance, the ribbing that keeps a table flat for decades, or surface choice between dragon scale, cast iron, and tool steel for welding out directly.
Fixture tables don’t slow you down; they help you make sure your part is built right and identical every time. And for a production run like Taylor’d’s Containers, they will benefit from having a fixture table system in their workshop.
If you have any more questions about fixture tables, make sure to drop a comment down below.
Cool table design, BUT…I build stainless frames. Customers will not allow carbon table scratches on the material. Stainless pulls and must be water cooled. Meaning rust on the table. What’s the fireball solution?
