What’s the Most Useful Upgrade You’ve Made to Your Workshop?
Hi everyone,
I’ve been looking for a few practical ways to improve my workshop setup, especially when it comes to keeping the work area organized and making repetitive projects a little easier.
I’m curious — what’s one upgrade, tool, fixture, or small change you’ve made that ended up being much more useful than you expected?
For me, I’m especially interested in workbench setups, clamping solutions, storage ideas, and anything that helps keep a cleaner and more efficient workspace.
Would love to hear what has worked well for everyone here.
Most functional yet retardely simple improvement to my work was running power to a castered 4x4 mobile general work bench.
Grabbed a reversed RV outlet so i can plug any extension cord into it. From that input it splits power to two 4 socket outlets mounted on opposite sides right below below the table top. Need to use a grinder, plug it in right at the workbench. Have 4 grinders with different setups, keep each one plugged into it, they are all hot and ready to go. Doing a wood project, unplug and store the grinders, plug all the sanders in.
Anything you need to power now can be plugged into those outlets and since the work bench is mobile, it can be moved anywhere and setup for every random project. Huge time saver for me.
Also, MDF tabletops with urethane are awesome for general use table tops. The urethane blocks liquids from soaking in and ruining the MDF, and when you trash the table top, just cut a new piece, coat it and you have a brand new tabletop ready to go. It’s like never ending cheap surfaces that you don’t care if you light on fire or cut into by accident.
A label maker. Mine does 3/4” wide. Get your drawers, cabinets and boxes marked.
I added a FireBall fixture table fitted with shelves, an attachment to mount my gas bottle, added a vise, added two shelf extensions to one end, and also tool set #3 including some additional tooling. It is basically a self-contained system that is designed to hold work in place and to provide a repetitive system of holding subsequent similar pieces in place. Saves time and is a pleasure to use for metal, or wood fabrication.
That’s a practical setup. Building power outlets directly into a mobile workbench seems especially useful when several tools are used in the same area, and being able to move the entire bench between projects adds a lot of flexibility.
The coated MDF top is also an interesting approach. For workbench accessories such as small parts trays, holders, or custom organizers, materials like wood, metal, and epoxy resin are all options depending on the application. Bond Craftor is one source I’ve come across for resin materials, although for a general-purpose bench I’d still choose the material based mainly on durability, cost, and how easy it is to replace.
A combination of integrated power, good lighting, and simple organization probably gives more practical benefit than many larger workshop upgrades.
Plasma table which then dovetails into the fixture table. I can’t even count the number of brackets and plates I’ve cut and welded for projects around the farm. Opened up an entire new world of fabrication.
A tapping arm, it cut manhours for the same project down to 10% of the last similar run. Only $1300 with all the possible attachments plus I made the base so I can put it on my fence or on my fireball table.
