Can Your Speed Square Do This? New tool Alert!
Can your speed square do this?
Today is a new tool birthday: the brand-new Fireball Miter squares.
The speed square is one of our favorite tools in the workshop. Nothing’s ever going to replace it, but it has weaknesses. Same with the framing square, We love it, but it too has its limits. So we thought, what if we could combine some of those strengths while addressing the weaknesses? That’s how the Fireball Miter Square was born.
This tool isn’t here to take the place of your other squares, it’s simply another option that does something special. We call it the Fireball Miter Square for a reason: it was really designed for layout on tubing.
We’ve made them out of stainless steel to keep costs down, and they come in a 3-pack set for $32.
Fireball Miter Square vs Speed Square
If you look at them side by side, the difference jumps out. The speed square’s hook is located on one of the 90° legs, leaving the hypotenuse open. On the Fireball Miter Square, the hook moves to the hypotenuse. It’s larger, and it’s only on one side. So in a sense, the Fireball Miter Square is like the speed square and framing square combined, with a long leg and a big hook.
In Use: Quick Layout
Here’s an example: if I want an opposite miter on tubing, I mark my length, put the Fireball Miter Square on the line, and wrap it around. Done. With a speed square, it’s a two-step process. Mark, roll, re-square. The Fireball Miter Square eliminates that.
It also shines on large radius tubing. A speed square barely hooks the edge and throws off your dimensions. The Fireball Miter Square grabs securely, stays square, and keeps the scale accurate.
Extra Features:
You can wrap perfect lines all the way around tubing.
Carry straight lines across multiple faces without losing reference.
Built-in scales on both sides, like a framing square, so you can reference from either edge.
Flat profile means it sits nicely on surfaces to check miter cuts and layout lines.
Cutouts let you jump over welds while still staying square.
Works for general layout too, hole locations, offsets, or even splitting a 45° into a 22.5°.
It’s surprisingly versatile. You can even use it as a small squaring tool after welding, since it balances itself with a built-in “kickstand.”
Our Final Thoughts:
Between the Fireball miter squares, the speed square, the framing square, and the combination square, you now have four great layout options. Each has strengths, and the Fireball Miter Square brings something new to the table.
They’re available now: 3-pack for $32. I think once you try them, you’ll see how handy they are in the shop.
Love the innovation! I can see where they’d be a great addition to our toolbox. I’ll be adding a set to my next order. Keep the new tool ideas coming!
This miter square is the sole reason I have joined this group! I am quite impressed with this little tool, but I have never worked with metal in my life. I am a carpenter and this tool would be really useful for cutting 4x4 and larger timbers with a 7 1/4 inch saw (Skil saw). The problem is many timbers have square and not rounded corners. Would it be possible to make this with square’d corners for us cellulose welders? I posted the same question to YT.
Can you PLEASE make an option of these in metric?
Fingers crossed for a restock. Saw the video and was immediately sold, showed my boss and they told me to order them! I was going during my lunch to order one set for my home shop and two sets for work but it seems everyone else saw the value in these as well. Hell of an innovative approach to solving problems simply.
Hey Nathan, I’m a woodworker as well as a metalworker.
Maybe they could make that sharp of a bend on one of these, but you’ve got a couple other options,
  1. Take the Fireball miter squares, make a wood shim thick enough to get past the radius, and accurately trim out the slots and edges - maybe a flush trim router??? Then glue it to the rectangular side. Maybe FB could make this as an add on product? Some aluminum square tubing could use that too.
  2. Woodpeckers and perhaps others make a side square that wraps layout lines far around the corner.
Jason,
This a great idea and really needed when we’re working with square/rect steel tubing because of the radiused corners.
Here’s an extension on the idea - sometimes we need to cut strange angles across tubing. Yes, I can use a framing square with Omni stair gauges after doing a bit of math - but sometimes a protractor or T bevel is the thing. But they suffer the same problem the squares do - the large radius makes them ineffective.
Add a little hole at each end and near the middle to your miter square, countersink the inside, add a low profile screw, and a long T bevel type blade. Presto, monster T bevel. See quick Solidworks concept drawing. The square is used the “wrong way around”.
Clever. I’ll have to prototype one and try it out
Love it! But being from Australia would you please release one in metric if you haven’t already?
Great square, I was lucky enough to order early and got a set!! Now I want 3 more sets, only hope you get enough requests to make an even bigger one!!
Yes we could do a 12 or 14 if there is enough interest
I hope there is!! Thank you for the reply!!
