Are the dragon wagon tables modular ?
Meaning will hole spacing still be correct at the edge with two bolted together or will there be a larger gap between the holes ?
Yes you can combine the tables.
One thing to be aware of @Fablife23, there will be a 1 hole gap (4" space) between the holes on the edge on one table to the holes on the edge of the other, but I’m setting up for my first large weldment and it’s easy to work around.
As @mRhAnKbOt mentioned, the distance between edge of table to center of first hole is 2", so when you join two together there will be a row of holes with 4" centers.
you ever get any Blems in the 30 x 54? I feel that thing calling my name every time I log onto site!
