DWx2 Final setup (for now)
Over the weekend I finally got my 36x24 Dragon Wagons setup.
It took a little bit of work. I was very pleased at how well I got the 2 tables. I blocked in the front and the back. Clamped some tooth block extensions across the top. I used 5x 3/4 shoulder bolts to hold it togeatger. I was able to get both tables almost perfect. I can slide a 1-2-3 block all across the top and the sides and it doesn’t catch at all. I would say it’s better then half a thou.
The side kick vise took a bit of work. It was sitting very low from the table top. With the v-washer there is no adjust. I took out the 5/8 shoulder bolt and v-washer out and replaced it with the 3/4 shoulder bolt and used this sketchy setup to get it flush before tightening it down.
For now I placed my 28 and 20 extension blocks around the outside. Same story blocked them all in and got them flush.
I spent some time figuring out a tool box for under the table. I didn’t want to waste any space. My go to is usually pack-out’s. But they aren’t that roomy for the space they occupy. Looked at several tool boxes. In the end the Harbor Fraight Series 3 27" top. Fit just about perfect. Leaves no wasted space on the small dragon wagon.
Small modifications I needed to lose the washers on the foot tray, I removed the lock bars from the box since the top can’t open now, and the handles needed to come off. I also messed with the slag trays. I’ve got it so all but one off the small ones I can remove. It got trapped by the vise. The two in the middle you can remove from the bottom.
People with more then one Dragon Wagon how did you lay them out?
