Continuing the discussion from Replacing Monster Square with Mutant Square:
@Fireball_Jason i ordered the magix square ans mutant square. Absolutely stoked to get them. Was wondering if you had time to answer the questions above by chance
@Jglenn76 The mutant square has the most room to access the weld. Approximately 5”x5” triangle. The funky L shaped tab is designed to be used on the 90 degree corner on the square body. The tab can be positioned to remain out of the way with a miter joint or a butt joint. Just use the different holes in the tab to accommodate the joint configuration.
