Jason
If i were to buy a 54" sq table and add another down the road what can I expect for flatness corner to corner? Will there be a FLAT transition at the seam where the tables meet.
I’ve gone crazy trying to get a BuildPro Alpha table flat. from plate to plate my square stops at each plate…I’ve added over 20 shims and its still a mess, so I hope you undertsand my concern
Yeah I’ve heard that’s a problem if you move the plates and don’t get all the foreign material out from underneath.
Yes I believe getting the plates dialed in shouldn’t be an issue. With the adjustment fasteners on the top it’s pretty easy to tune it in.
