Metric Toothblock
Hi, would love to know wich mm steps the toothblock has in the european version, or if the teeth are spaced in imperial.
Thanks a lot.
Elias
Check out all the info you need at the link below.
Both the 16mm and 19mm sytem toothed blocks work in 2.5mm steps, not Inch (Thankfully.
All the best,
Dan Chambers
ok nice thanks a lot:)
Perfect. I noticed a few details that are mixed up on the european website. For example the picture in the description of the 16mm risor block doesnt match.
And another thing is the desciption of the Toothblock confused me because it said inch spaced tables…
thanks
