16mm tooth block still allow for 1/8" and 1/16th" adjustments?
Hi,
Just double checking myself here before ordering some tooth blocks. I have a 16mm fixture table with 2” hole spacing. Will the 16mm tooth block still allow for 1/8" and 1/16th" adjustments if used on a 16mm table with 2" hole spacing? I want to keep my measurements in Imperial and as accurate as possible while still using my existing metric 16mm table.
Thanks
If the table hole spacing is 2” then yes that is compatible with the tooth blocks.
Perfect, that’s what I had thought.
I appreciate the reply Jason. Have a happy new years eve and day!
