Hi,
I purchased some 6" stop blocks for the ¾" system and am milling holes into C6 Channel to make my own mini welding table piece with specific distances between the holes (attached below). This will become part of a saw table, and will not be exposed to intense heat like a usual welding table; it will just have pieces of stainless-steel sliding across it.
I’d like to use C6 x 10.5 (0.314" or 5/16" thickness on top) that I have on hand, but will that cause a lot of wobbling/play? I’m using this to premeasure lengths for cutting material with 1/16" tolerance with the cuts ranging from around 27" to 70". I plan to have the pins positioned such that there are 2.8 inches between them. My alternative is the C6 x 13, which is 0.437" or 7/16" thick on top, closer to your 1/2" thickness, but I would only choose this if it would make a significant difference.
What do you suggest?
Thanks so much,
Sarah
