Hey @Fireball_Jason ! John P. here. One of our mutual customers shared your discussion with me!
A couple quick points:
- Just to second what you said, you indeed were NOT making tables when you made that video, or when I wrote that article. And your video is a fantastic, and fair, assessment with all the info you had available to you. It’s what inspired me to put some thought and research into all this. Furthermore, you always approach topics you’re investigating with an open mind and a well reasoned approach. Thanks for the effort you put into that for us!
- Now that you’re producing tables, they are amazing. I saw them at Fabtech and would have said Hi, but you’re always swamped with fans.
I always think this topic is fascinating because valid arguments can be made from different perspectives.
I’m sure many people are familiar with the old phrase, “No one ever got fired for hiring IBM.” The reference being that when you buy the absolute best no one can accuse you of doing the wrong thing. And one could argue this applies to everything (almost). If we were all billionaires, what the heck… give me a Blueco! It’s just money. And since you allegedly can’t get anything better we can cross that off the list if anything goes wrong.
On the other end of the spectrum, for an individual or small business doing work with 1/8" or 1/4" tolerances, it might be irresponsible to spend exorbitantly when funds might be better deployed elsewhere.
I think it’s great that there are a variety of options to meet different needs. If I were to oversimplify my view of the market it would look something like this. (Excuse the white board sketch.)
Perhaps I can also share three thoughts tangentially related to this topic.
Variable Build Quality
Tables that utilize material removal processes, such as milling or grinding, should always have an edge when it comes to consistency. Assuming the machines doing the work are cared for, calibrated, and professionally operated, the output should be remarkably consitent.
Tables that are fabricated from laser cut parts are subject to far more risk factors including the quality of the material, the consistency of the thickness of the material, and the skill and processes employed with their assembly.
Building really flat tables is MUCH harder than the other method, so it’s a more an experienced-labor intensive process. The cost advantages come from material savings which can offset some of that labor, combined with the speed of laser cutting compared to milling.
Strength and Durability
Clearly more and thicker is going to be stronger, all other things being equal! But the question is, how strong is enough? From my perspective the key is to have enough strength that whatever you put on the surface doesn’t cause more deflection than is acceptable for the tolerances required.
So if you need to maintain 1" of tolerance, the weight on the table can’t cause it to sag more than that or you simply can’t get the job done.
For people who are only putting a few hundred pounds on the surface, all of these tables are fine. But if you’re going to put 4,000lbs… well, now we need to understand how the table is going to behave before we can say if it’s appropriate.
Flatness
This is again an area where material removal processes have a huge advantage. It kind of doesn’t matter what the material looks like before, because the after is always going to be the same.
Conversely, fabricated tables have to fight the natural tendency of the material to curve. You have to worry about specs of dirt getting between parts, or burs on the edges of material. And many other things.
When done correctly, the results can be surprisingly good. For example, here’s a scan from our $100k Verisurf laser system of one of our 70"x140" tables. Personally, I’m super impressed by how flat we got it. You can see one little problem area on the end, but even that is pretty darn good, plus it’s down, not up, which is at least better.
Anyway, I hope this added a little value. I can’t wait to see what others have to say. I’m always anxious to learn how we can all do things better!
