New Fireball Double Riser and Tooth Block
The new Fireball Double Riser and Tooth Block Fixture is designed to bring more flexibility and repeatability to everyday fabrication setups. Built as a modular two-piece system, it consists of a bottom tooth block chassis and a separate riser that lock together to form a true 90-degree fixture. This design allows you to adapt quickly to different heights and configurations without changing your workflow.
Where the Fireball double row fixture really shines is in real-world use. It allows you to support material on one side while using the other side for fences, stops, or offsets. With the help of magnetic shims, precise measurements can be dialed in and repeated consistently, making it easy to hit exact dimensions while staying square in all directions.
The hole pattern along the side of the riser adds even more versatility. Three-axis square pins can be used to create fences.
Additional risers can be mounted to form shelves or offset planes, and setups can be built from either the front or the back of the fixture.
The riser also accepts Fireball tabs, letting you clamp parts perpendicular just like a Fireball square, with shims used for fine adjustments or fully magnetic setups for speed.
Overall, the double-wide riser system expands what’s possible compared to a single-width fixture. It’s a powerful option for complex assemblies, repeatable offsets, and faster, more reliable setups in the shop.
Are these available for the 5/8 inch hole tables? ( Dragon Wagon )
Hi Julian, sorry for the slow answer. Right now the Double Riser and Tooth Block is made for 3/4" tables only, and we don’t have a 5/8" version in the works. I’ve passed your request along to our product team so they know there’s interest from Dragon Wagon owners.
Victor
Fireball Tool
Publishing a dimensioned drawing of the riser-to-chassis connection and hole spacing would make it much easier to plan a setup around existing Fireball fixtures. A stated load rating would help too.
The magnetic shims should make repeat offsets quick, but I’d keep the mating faces clear of spatter and grinding dust; even a small particle between the riser and chassis can throw off the square when you rebuild a setup.
A useful detail would be the load rating for the riser when it’s mounted outboard or stacked. Those setups add leverage, so knowing the supported load would help plan heavier assemblies safely.
