Post the machines you wished could do more
I’m going to find a powered ram with a 40 taper milling head. For this T lathe . It has a 30” chuck and a 8” spindle bore with 10 hp. I can run a loop dro on the x that’s hooked to the inverter drive for constant surface feet from center to outer. When the mill head is figured out. Which I will probably build with a big ball screw and stepper motors spindle and ram. I’m still pondering the Z axis. I could just put a smaller bed mill on the table. I’m always open for feedback.
