What is the table thickness?
What are the hole dia?
What is the weight of each 12x24in panel?
Theyr’e 5/8 diameter holes, 5/8 depth.
The casting is thicker but in the hole locations they are counter bored on the under side to create a 5/8 thickness where the hole is.
They’re roughly 55-60 lbs each 24x12 plate, the plate thickness is about 3/4"
Yean thanks. I’ll be ordering.
