Could you please suggest the dimensions to help me on the assembly process?
Thanks
Thanks
4 to 5 foot lengths would be just fine.
Thank you.
To be honest, you should be able to get the same 3 point benefit of using a triangle, by running 3 3/4" bolts up through the fixture holes, and positioning your sawhorses under them. No need to use a bunch of tubing making a triangle that’s most likely only going to be used once. Just keep the bolts out of the way of where your frame and the fixtures for positioning it will be. You could also thread smaller bolts (or long set screws) down through the holes for the mounting straps or set screws from the top, down onto the sawhorses to support the table on 3 points. Lots of ways to use the built in holes to accomplish the same effect, without making a tubing triangle
Make sense, and it will very easy to do. Thanks a lot.
No don’t do that. The plate will defect at those points. The plate needs to be supported. The triangle is just tacked together. It’s easy to disassemble and repurpose the material.
Thank you, it’s true, there are many opportunities to reuse the tubes.
Unfortunately the carrier is delaying the delivery, I hope to get soon.
I am a long-time planning to buy this table.
Cheers
