Trying to contact Fireball so I can laser harden your metal tables
I work with the world’s most advanced lasers, the manufacturing of world’s most thermally insulative aerogel fabrics, and in the manufacturing of volcanic mineral composites. Our materials are used in the most expensive machinery and structures ever made in the solar system since the 1950’s, from the depths of the sea to outer space our materials have been proven for decades.
I noticed you had a youtube video showing how awesome your steel/cast iron tables were, how they were built, and how proud you were of them in real world product tests. I was encouraged to contact the owner of Fireball to tell him that I can use some of my talents and connections to help him make even better tables.
Jason, I would like to show you how to laser etch your steel tables to be forever and permanently hydrophobic or hydrophilic, to be anti-viral or to alter it’s color when viewed in sunlight. I can show you how to clean off all corrosion and then re-harden the steel to be stronger than new, yes stronger than new.
Every single thing I work with is for sure the best in the world, the most advanced, the best of the best. I can show you how to also make non-metallic welding tables made out of volcanic basalt minerals which are 10x less electrically conductive than fiberglass, is 5x lighter in weight than steel, and is 3x more durable. Would you like me to show you how to make a fixture or jig table that is more thermally stable than steel, lasts 100 years, can easily be moved around, and can be constructed with a free-span length up to 100ft! Yes, one hundred feet. Did you know we make composite roadway bridges, we make thermal coatings for NASA rocket engines, and we make fireproofing for submarines. It would be very feasible for me to help you big gigantic fixture tables. And yes, if you wanted to you could weld on them if you had a ground wire rigged.
We also make aerogel that keeps astronauts from freezing in space and volcano scientists from being burned by hot lava. I could easily help you sell welding blankets, gloves, and safety equipment that lasts a hundred years.
Contact me, I’m always open for collaboration in North America.
