Maximus Bar Clamps
I just received my Mini Maximus Clamps and I see they have a set screw to hold them in place on the bar stock I will use them with. My question is: Can I drill and tap my Maximus Bar Clamps in a similar fashion without compromising their structural integrity??
Absolutely, it will be a feature that will be available in future versions.
Thank you @Fireball_Jason for the speedy response! I will drill and tap my other clamps now.
another question on these clamps, I assume they will be fine with 25*50mm rectangular hollow section?
Yes 25x50mm works
When did you add the set screw?
I just picked up a set of forge 6.5, 3.5 and mini. They all have set screws in them.
Probably a year ago we started adding them.
