Inspired by Jason’s question about when to change your bandsaw blade, what blade do you prefer to use on the bandsaw?
List your specifics:
Saw type - blade length - width x thickness - teeth per inch - application
DoAll C-916M horizontal bandsaw. 158" x 1" x .035" 4/6 German made blade. Cutting only metal from 1/2" square bar to 12" I-beam.
Delta 14" vertical bandsaw. 93" x .375" x .035 16/18" blade. Used mainly for contour cutting wood and thin sheet metal. Also have a the same blade in a 93" x .025" x 4tpi for ripping/cross cutting larger chunks of wood.
